<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-st-louis-zone-letter-cancellation-of-option-a02-windshield-tinted-glass-1176.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</guid>
										<title>1972 Corvette:  Service News:  Front Fender Skirt Availability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</guid>
										<title>1968 Corvette: Recall: Product Campaign No. 8005 Left Front Fender Skirt to Brake Pipe Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1977-corvette-service-bulletin-cemented-weatherstrip-removal-716.html</guid>
										<title>1975 - 1977 Corvette: Service Bulletin: Cemented Weatherstrip Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1977-corvette-service-bulletin-cemented-weatherstrip-removal-716.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-glass-roof-panel-trim-separation-714.html</guid>
										<title>1978 - 1979 Corvette: Service Bulletin: Glass Roof Panel Trim Separation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-glass-roof-panel-trim-separation-714.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1978-corvette-service-bulletin-rear-bumper-cover-wavy-31.html</guid>
										<title>1977 - 1978 Corvette:  Service Bulletin:  Rear Bumper Cover Wavy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1978-corvette-service-bulletin-rear-bumper-cover-wavy-31.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</guid>
										<title>1973 Corvette:  Service Bulletin:  Rear Window Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</guid>
										<title>1968 Corvette: Service Bulletin: Lubrication of Window Regulator Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</link>
