<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-windshield-washers-1173.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-two-tone-paint-combinations-1144.html</guid>
										<title>1956 Corvette:  Production Information:  Two-Tone Paint Combinations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-two-tone-paint-combinations-1144.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</guid>
										<title>1958 Corvette: Service Bulletin: Nylon Headlamp Adjusting Screw Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-new-weatherstrip-seals-976.html</guid>
										<title>1956 Corvette:  Service Bulletin:  New Weatherstrip Seals</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-new-weatherstrip-seals-976.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</guid>
										<title>1961 Corvette:  Service Bulletin:  Corvette Grille Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-1961-convertible-top-adjustments-41.html</guid>
										<title>1961 Corvette:  Service Bulletin: 1961 Convertible Top Adjustments</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-1961-convertible-top-adjustments-41.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Front and Rear Door Glass Loose in Run Channels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</guid>
										<title>1953 - 1954 Corvette: Service Bulletin: Water Leaks - Corvette Doors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1961-corvettes-chevrolet-central-office-letter-1961-corvette-hardtops-to-fit-prior-years-1245.html</guid>
										<title>1956 - 1961 Corvettes:  Chevrolet Central Office Letter:  1961 Corvette Hardtops to Fit Prior Years</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1961-corvettes-chevrolet-central-office-letter-1961-corvette-hardtops-to-fit-prior-years-1245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-corvette-body-repair-175.html</guid>
										<title>1953 Corvette: Service Bulletin: Corvette Body Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-corvette-body-repair-175.html</link>
