<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-1971-corvette-axle-usage-corrections-1054.html</guid>
										<title>1971 Corvette:  Service Bulletin:  1971 Corvette Axle Usage Corrections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-1971-corvette-axle-usage-corrections-1054.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</guid>
										<title>1975 Corvette:  Service News:  Radiator and Fan Shroud Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-1973-corvette-service-news-new-vacuum-modulator-hoses-839.html</guid>
										<title>1972 - 1973 Corvette: Service News: New Vacuum Modulator Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-1973-corvette-service-news-new-vacuum-modulator-hoses-839.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: Knowing How Your 1963 - 1982 Corvette`s Cooling System Can Prevent a Steaming Summer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</guid>
										<title>1976 Corvette:  Parts Chart:  Delco Quadrajet Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</link>
