<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: Poly Performance: Putting Polyurethane Bushings on Your Late Model Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Steering Column Popping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</guid>
										<title>1994 - 1996 Corvette: Service Bulletin: Intermittent Steering Column Snap or Clink Noise When Turn</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-service-manual-update-front-leaf-spring-compressor-adapter-623.html</guid>
										<title>1988 Corvette: Service Bulletin: Service Manual Update Front Leaf Spring Compressor Adapter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-service-manual-update-front-leaf-spring-compressor-adapter-623.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</guid>
										<title>1985 Corvette:  Service News:  Revised Differential Case Cross Pin Installation Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</guid>
										<title>1988 - 1990 Corvette: Service Bulletin: Power Steering Shudder / Groan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html</guid>
										<title>1984 Corvette:  Service News:  Axle Lube Change</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-rear-axle-differential-cross-shaft-retention-628.html</guid>
										<title>1984 Corvette: Recall: Rear Axle Differential Cross Shaft Retention</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-rear-axle-differential-cross-shaft-retention-628.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-horizontal-and-vertical-uniframe-alignment-dimensions-799.html</guid>
										<title>1984 Corvette: Service News: Revised Horizontal and Vertical Uniframe Alignment Dimensions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-horizontal-and-vertical-uniframe-alignment-dimensions-799.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-ride-harshness-z51-suspension-626.html</guid>
										<title>1984 Corvette: Service Bulletin: Ride Harshness - Z51 Suspension</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-ride-harshness-z51-suspension-626.html</link>
