<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-fuel-tank-pressure-control-valve-1166.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Fuel Pump Driveability Issue - Diagnostic Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</guid>
										<title>1992 Corvette: Recall: Oil Leak at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Multec Fuel Injectors / Cleaning Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</link>
