<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
