<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-air-conditioning-cooling-capacity-loss-1162.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 350 H.P. Factory A/C Operating Temperatures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-air-conditioning-diagnosis-845.html</guid>
										<title>1967 Corvette: Service News: Air Conditioning Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-air-conditioning-diagnosis-845.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-lack-of-heat-with-controls-in-full-on-position-968.html</guid>
										<title>1964 Corvette:  Service Bulletin:  Lack of Heat with Controls in Full &quot;On&quot; Position</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-lack-of-heat-with-controls-in-full-on-position-968.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-air-conditioning-thermostatic-expansion-valve-replacement-759.html</guid>
										<title>1966 Corvette: Service News: Air Conditioning Thermostatic Expansion Valve Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-air-conditioning-thermostatic-expansion-valve-replacement-759.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-heater-hose-routing-change-required-1039.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Heater Hose Routing Change Required</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-heater-hose-routing-change-required-1039.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-air-conditioning-changes-913.html</guid>
										<title>1963 - 1964 Corvette:  Service News:  Air Conditioning Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-air-conditioning-changes-913.html</link>
