<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-techline-infotainment-dvd-software-update-1161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-convertible-customer-satisfaction-program-17245-mechanical-trunk-release-may-not-operate-1371.html</guid>
										<title>2016 - 2017 Corvette Convertible: Customer Satisfaction Program: 17245  Mechanical  Trunk Release May Not Operate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-convertible-customer-satisfaction-program-17245-mechanical-trunk-release-may-not-operate-1371.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-update-performance-timer-missing-1262.html</guid>
										<title>2016 Corvette:  Service Update - Performance Timer Missing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17-na-025-repeated-radio-display-resets-volume-control-inoperative-waiting-for-update-media-message-voice-command-for-calling-bluetooth-phone-contacts-inoperative-service-rear-vision-system-message-radi-1326.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #17-NA-025: Repeated Radio/display Resets, Volume Control Inoperative, Waiting for Update Media Message, Voice Command For Calling Bluetooth Phone Contacts Inoperative, Service Rear Vision System Message, Radi</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17-na-025-repeated-radio-display-resets-volume-control-inoperative-waiting-for-update-media-message-voice-command-for-calling-bluetooth-phone-contacts-inoperative-service-rear-vision-system-message-radi-1326.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5467A: Repeat Codes P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-hd-radio-operation-1203.html</guid>
										<title>2014 Corvette:  GM TechLink:  HD Radio Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-hd-radio-operation-1203.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-bulletin-instrument-cluster-driver-information-center-goes-blank-or-analog-speedometer-inaccurate-1229.html</guid>
										<title>2015 Corvette:  Service Bulletin:  Instrument Cluster Driver Information Center Goes Blank or Analog Speedometer Inaccurate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-bulletin-instrument-cluster-driver-information-center-goes-blank-or-analog-speedometer-inaccurate-1229.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</guid>
										<title>2014 Corvette: GM TechLink Article: HVAC Temperature Fluctuations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
