<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-chevrolet-inter-organization-letters-1962-corvette-power-teams-125.html</guid>
										<title>1962 Corvette: Chevrolet Inter-Organization Letters: 1962 Corvette Power Teams</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-chevrolet-inter-organization-letters-1962-corvette-power-teams-125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</guid>
										<title>1959 - 1961 Corvette:  Service News:  Fuel Injection Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</guid>
										<title>1959 Corvette:  Service News:  Fuel Injection Pump Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-service-bulletin-harrison-aluminum-radiator-repair-1180.html</guid>
										<title>1960 - 1962 Corvette:  Service Bulletin:  Harrison Aluminum Radiator Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-service-bulletin-harrison-aluminum-radiator-repair-1180.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</guid>
										<title>1956 - 1962 Corvette:  Intake Manifold Casting Numbers and Date Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-engine-valve-noise-1000.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Engine Valve Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-engine-valve-noise-1000.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Oil Consumption</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</guid>
										<title>1957 - 1961 Corvette: Service Bulletin: Oil Consumption Complaints</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</link>
