<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-valve-body-governor-and-rear-pump-changes-1156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</guid>
										<title>1955 Corvette: Service Bulletin: Rear Engine Mountings 1955 Passenger 6 &amp; 8 Cylinder With Powerglide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</guid>
										<title>1958 - 1959 Corvette: Service Bulletin: Vacuum Modulation System Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</guid>
										<title>1956 Corvette Service News:  Corvette Transmission Control Lever Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Shift Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</guid>
										<title>1962 - 1963 Corvette:  Service Bulletin:  Governor Rattle After Reverse Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</guid>
										<title>1956 - 1957 Corvette:  Service News:  Corvette Transmission Mount</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</guid>
										<title>1953 Corvette: Service Bulletin: New Spoke Flywheel and Converter Attachment to Flywheel - Late Powerglide Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</guid>
										<title>1958 Corvette: Service Bulletin: Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</link>
