<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-recall-notice-rear-suspension-tie-rod-assembly-1154.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - New Vehicle Preparation for Magnetic Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</guid>
										<title>1998 - 2004 Corvette:  Press Release: Active Handling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-rear-axle-assemble-procedure-and-special-tools-448.html</guid>
										<title>1997 - 2003 Corvette: Service Manual Update: Revised Rear Axle-Assemble Procedure and Special Tools</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-rear-axle-assemble-procedure-and-special-tools-448.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</guid>
										<title>Road Test: Active handling: Corvette`s revolutionary new option increases safety and performance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-corvette-crossmember-design-and-manufacturing-797.html</guid>
										<title>1997 - 2004 Corvette: Technical Article: Corvette Crossmember Design and Manufacturing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</guid>
										<title>2003 Corvette:  Technical Article:  Magnetic Selective Ride Control - First Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</guid>
										<title>2003 Corvette: Technical Article: Magnetic Ride - Star Wars Meets the 50th Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</guid>
										<title>2004 Corvette: Recall: Lower Control Arm Ball Stud Washer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</link>
