<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-ignition-distributors-and-engine-timing-892.html</guid>
										<title>1959 Corvette:  Service News:  1959 Ignition Distributors and Engine Timing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-ignition-distributors-and-engine-timing-892.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</guid>
										<title>1965 Corvette:  Service News:  Vent the Window Regulator Motor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-spark-plug-changes-178.html</guid>
										<title>1957 Corvette: Service News: Spark Plug Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-spark-plug-changes-178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-electric-windshield-wiper-information-1067.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Electric Windshield Wiper Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-electric-windshield-wiper-information-1067.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-news-setting-v-8-timing-at-1-000-engine-rpm-discontinued-1210.html</guid>
										<title>1955 - 1957 Corvette: Service News:  Setting V-8 Timing at 1,000 Engine RPM Discontinued</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-news-setting-v-8-timing-at-1-000-engine-rpm-discontinued-1210.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Generator Belt Misalignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1955-corvette-service-bulletin-distributor-dust-contamination-782.html</guid>
										<title>1953 - 1955 Corvette: Service Bulletin: Distributor Dust Contamination</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1955-corvette-service-bulletin-distributor-dust-contamination-782.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</guid>
										<title>1958 Corvette: Service Bulletin: Nylon Headlamp Adjusting Screw Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</guid>
										<title>1955 - 1957 Corvette: Service Bulletin: V-8 Distributor Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</link>
