<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-powerglide-production-variations-1056.html</guid>
										<title>1959 Corvette Service News:  1959 Powerglide Production Variations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-powerglide-production-variations-1056.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Vacuum Modulator Spring Throttle Valve Inner Spring</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Transmission Identification Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</guid>
										<title>1953 - 1954 Corvette:  Service News:  Powerglide Clutch Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</guid>
										<title>1953 Corvette:  Service Bulletin:  Powerglide Transmission Slippage and Chatter in Automatic Low and Drive Range</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Shift Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</guid>
										<title>1955 Corvette: Service Bulletin: Foreign Material in Clutch Housings, Secondary Road Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</link>
