										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</guid>
										<title>1963 Corvette:  Field Service Engineering:  Intake Manifold Baffle Rivet Hole Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-chevrolet-inter-organization-letters-1962-corvette-power-teams-125.html</guid>
										<title>1962 Corvette: Chevrolet Inter-Organization Letters: 1962 Corvette Power Teams</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-chevrolet-inter-organization-letters-1962-corvette-power-teams-125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Oil Level Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Oil Level Gauge Dipsticks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</guid>
										<title>1960 - 1961 Corvette: Zone Letter: Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-air-pump-noise-air-injection-reactor-system-1026.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Air Pump Noise - Air Injection Reactor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-air-pump-noise-air-injection-reactor-system-1026.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Increased Capacity Fuel Pump</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</guid>
										<title>1958 Corvette: Service Bulletin: Siphon Breaker Plate Unit #7014900 Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</link>
