<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-gm-techlink-bluetooth-issues-114.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</guid>
										<title>2005 Corvette: Service Bulletin: Removal of Radio Fuse Before Attempting to Program/Reprogram Modules Using Service Program System (SPS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</guid>
										<title>2009 Corvette: Service Campaign: OnStar System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</guid>
										<title>2006 Corvette: Electrical Schematic: Exterior Lamps Circuit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Misfire DTCs P0300, P1380, P1381 and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</guid>
										<title>2005 - 2012 Corvette: GM TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
