<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-production-information-price-change-am-fm-radio-1138.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Power Windows - Special Policy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</guid>
										<title>1965 - 1966 Corvette:  Service Bulletin:  Temperature Gauge Reading Too High</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  RPO K-66 Wiring Diagram for Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</guid>
										<title>1967 Corvette:  Chevrolet PartsMart:  Fusible Links</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-rear-bulb-re-incarnation-243.html</guid>
										<title>1966 Corvette: Technical Article:  Rear Bulb Re-incarnation</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</guid>
										<title>1963 Corvette:  Delco Service Bulletins:  Delco Radio Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</guid>
										<title>1963 Corvette:  Chevrolet Parts and Accessories Bulletin:  Delcotron Generator Replacement Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</link>
