<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-production-information-positraction-axles-1137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</guid>
										<title>1966 - 1969 Corvette: Tech Article:  Building 427 Engines - Corvette News</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</guid>
										<title>1963 Corvette: Service News: Radiator Service Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</guid>
										<title>1966 Corvette: Service Bulletin: Engine Surge - 1966 427ci Corvettes with Holley Carburetor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</guid>
										<title>1965 Corvette: Service Bulletin: Valve Spring Cap Failure - 425 H.P., 396 ci. Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Dying on Quick Right Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
