<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-delco-service-bulletin-quadrajet-carburetor-service-charts-1135.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Holley Model 2300 Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</guid>
										<title>1982 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Mono and Stereo Radio System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</guid>
										<title>1968 Corvette:  Chevrolet Service News:  1968 Corvette Courtesy Light Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</guid>
										<title>1969 Corvette:  Service Bulletin:  Choke Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-chevrolet-engineering-service-letter-radio-service-update-910.html</guid>
										<title>1969 - 1970 Corvette: Chevrolet Engineering Service Letter:  Radio Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-chevrolet-engineering-service-letter-radio-service-update-910.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
