										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</guid>
										<title>1974 Corvette: Service Bulletin: Soft Push Rod Guides</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Fuel Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Upper Radiator Hose Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</guid>
										<title>1968 Corvette:  Service News:  Tune-up Specification Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</guid>
										<title>1964 - 1965 Corvette: Technical Article: &quot;30-30&quot; Solid Lifter Cam Valve Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-exploded-views-of-1982-cross-fire-injection-unit-with-part-numbers-1221.html</guid>
										<title>1982 Corvette:  Exploded Views of 1982 Cross-Fire Injection Unit with Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-exploded-views-of-1982-cross-fire-injection-unit-with-part-numbers-1221.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</guid>
										<title>1975 Corvette:  Service News:  Radiator and Fan Shroud Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-3x2-carburetor-to-manifold-gasket-728.html</guid>
										<title>1967 Corvette: Service News: 3X2 Carburetor-to-Manifold Gasket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-3x2-carburetor-to-manifold-gasket-728.html</link>
