<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-recall-notice-product-emission-campaign-85c22-high-output-ignition-coil-1130.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</guid>
										<title>1984 Corvette: Recall: Positive Battery Cable Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</guid>
										<title>1989 Corvette: Service Bulletin: Bose Amplifiers Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</link>
