<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-oil-leaks-from-rear-of-engine-522.html</guid>
										<title>1992 Corvette: Service Bulletin: Oil Leaks From Rear of Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-oil-leaks-from-rear-of-engine-522.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: Tail Pipe Smoke on Startup</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</link>
