<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</guid>
										<title>1969 - 1976 Corvette: Service Bulletin: Air Conditioning Compressor Drive Belt to Radiator Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html</guid>
										<title>1976 Corvette: Service Bulletin: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-refrigerant-leaks-air-conditioning-compressor-superheat-switch-838.html</guid>
										<title>1972 Corvette: Service News: Refrigerant Leaks Air Conditioning Compressor Superheat Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-refrigerant-leaks-air-conditioning-compressor-superheat-switch-838.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-service-news-false-a-c-compressor-seizure-vehicles-subjected-to-extended-storage-949.html</guid>
										<title>1968 - 1982 Corvette:  Service News:  False A/C Compressor Seizure - Vehicles Subjected to Extended Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-service-news-false-a-c-compressor-seizure-vehicles-subjected-to-extended-storage-949.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</guid>
										<title>1971 Corvette:  Service Bulletin:  Air Conditioning Equipped Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Condenser and Receiver-Dehydrator Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</link>
