<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</guid>
										<title>1970 Corvette:  Service Bulletin:  Water Pump Bearing and/or Shaft Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Gas Line Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</guid>
										<title>1968 Corvette:  Features Sheet:  Chevrolet L88 Engine Assembly Features</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-1973-corvette-service-news-new-vacuum-modulator-hoses-839.html</guid>
										<title>1972 - 1973 Corvette: Service News: New Vacuum Modulator Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-1973-corvette-service-news-new-vacuum-modulator-hoses-839.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Rear Axle Identification Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</guid>
										<title>1969 Corvette:  Service News:  Delcotron Battery Terminal Contacting Rocker Cover</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</link>
