<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Engine Repair with Crankshaft Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</guid>
										<title>2014 Corvette:  GM TechLink:  Oil Leak after the Harmonic Balancer is Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-21-na-109-diagnostic-information-on-engine-vibration-may-3-2021-1510.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #21-NA-109: Diagnostic Information on Engine Vibration - (May 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-21-na-109-diagnostic-information-on-engine-vibration-may-3-2021-1510.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-techlink-low-oil-pressure-conditions-1407.html</guid>
										<title>2015 - 2019 Corvette:  TechLink:  Low Oil Pressure Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-techlink-low-oil-pressure-conditions-1407.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5165e-oil-dripping-out-of-the-air-filter-box-1368.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5165E: Oil Dripping Out Of The Air Filter Box</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5165e-oil-dripping-out-of-the-air-filter-box-1368.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</guid>
										<title>2015 - 2018 Corvette Z06: Special Coverage Adjustment - N202302720 On Track Performance Engine Overheating</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-oil-change-information-for-2014-2017-chevrolet-corvette-1311.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin: Oil Change information For 2014 - 2017 Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-oil-change-information-for-2014-2017-chevrolet-corvette-1311.html</link>
