<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</guid>
										<title>1992 Corvette: Recall: Oil Leak at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</guid>
										<title>1995 Corvette: Recall: Distributor Vacuum Vent Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</guid>
										<title>1988 - 1989 Corvette: Recall: Evaporative Emission Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</guid>
										<title>1986 - 1990 Corvette: Service Bulletin: New Design Cylinder Heads Production Change Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html</guid>
										<title>1984 Corvette:  Service News:  Axle Lube Change</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</guid>
										<title>1984 Corvette:  Recall Notice:  Product Safety Campaign 84C01 A.I.R Pump Pulley May Loosen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Fuel Pump Driveability Issue - Diagnostic Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</guid>
										<title>1992 - 1996 Corvette:  Service Bulletin:  Oil Leaks Between Intake Manifold and Engine Block</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</link>
