<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-whine-noise-in-radio-1113.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</guid>
										<title>1982 Corvette: Service Bulletin: Spark Plug Fouling/Driveability Improvements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness at Starter Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</guid>
										<title>1969 Corvette:  Inter-Organization Letter:  1969 Delcotron Generator with Integrated Voltage Regulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</guid>
										<title>1969 Corvette:  Service News:  Battery with Side-Mounted Terminals</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Delcotron Noise (Moan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</guid>
										<title>1979 Corvette: Service Bulletin: Halogen Sealed Beams</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</link>
