<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-headlamp-circuit-diagnosis-1101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Delcotron Noise (Moan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-united-delco-bulletin-universal-horns-946.html</guid>
										<title>1968 Corvette:  United Delco Bulletin:  Universal Horns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-united-delco-bulletin-universal-horns-946.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Power Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</guid>
										<title>1968 Corvette:  Chevrolet Service News:  1968 Corvette Courtesy Light Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</guid>
										<title>1979 - 1982 Corvette:  Service Bulletin:  No AM Reception with Replacement Power Antenna Mast</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</link>
