<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-service-bulletin-100-octane-fuel-calibration-1320.html</guid>
										<title>2015 - 2016 Corvette Z06: Service Bulletin: 100 Octane Fuel Calibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-service-bulletin-100-octane-fuel-calibration-1320.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</guid>
										<title>2014 Corvette: GM TechLink Article: Heated Seat May Turn Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PIP5159B: Engine Misfire May Be Due To loose Spark Plug Wires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Malfunction Indicator Light (MIL) Illuminated, DTC P0420 and P0430 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</guid>
										<title>2016 Corvette:  Service Bulletin:  #16-NA-219: GPS Inoperative, Red Line Across GPS Indicator, or the Location is Stuck in Warren Michigan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-infotainment-display-screen-conditions-1159.html</guid>
										<title>2015 Corvette:  GM TechLink:  Infotainment Display Screen Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-infotainment-display-screen-conditions-1159.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 13, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</guid>
										<title>2015 Corvette:  GM TechLink:  Incorrect Song Information Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17-na-025-repeated-radio-display-resets-volume-control-inoperative-waiting-for-update-media-message-voice-command-for-calling-bluetooth-phone-contacts-inoperative-service-rear-vision-system-message-radi-1326.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #17-NA-025: Repeated Radio/display Resets, Volume Control Inoperative, Waiting for Update Media Message, Voice Command For Calling Bluetooth Phone Contacts Inoperative, Service Rear Vision System Message, Radi</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17-na-025-repeated-radio-display-resets-volume-control-inoperative-waiting-for-update-media-message-voice-command-for-calling-bluetooth-phone-contacts-inoperative-service-rear-vision-system-message-radi-1326.html</link>
