<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Holley Model 2300 Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</guid>
										<title>1969 Corvette:  Inter-Organization Letter:  1969 Delcotron Generator with Integrated Voltage Regulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</guid>
										<title>1977 - 1982 Corvette:  Service Bulletin:  Care and Maintenance of Tape Players and Cartridges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</guid>
										<title>1981 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</guid>
										<title>1969 Corvette:  Service News:  Directional Signal Switch Removal and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
