<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</guid>
										<title>1967 - 1968 Corvette:  Engineering Service Note:  Idle Cooling and Dieseling on Corvette with 427 CU IN Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 396-425 H.P. RPO L-78 Incorrect Build</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</guid>
										<title>1966 Corvette: Technical Article:  Adjusting the Fast-Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</link>
