<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</guid>
										<title>1980 - 1982 Corvette:  Service News:  Differential Side Bearing Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</guid>
										<title>1967 - 1968 Corvette:  Engineering Service Note:  Idle Cooling and Dieseling on Corvette with 427 CU IN Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Fuel Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Water Entry Into Fuel Tank (#1092)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-vehicle-speed-sensor-servicing-677.html</guid>
										<title>1981 Corvette: Service Bulletin: Vehicle Speed Sensor Servicing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Gas Line Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</link>
