										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</guid>
										<title>1957 - 1961 Corvette: Service Bulletin: Oil Consumption Complaints</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Radiator Core Usage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Crankcase Breather Assembly (Cap)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</guid>
										<title>1965 - 1967 Corvette:  Tonawanda Engine Service Notes:  Valve Springs, Rocker Arms, Camshafts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-chevrolet-central-office-letter-aluminum-radiator-factory-replacement-policy-762.html</guid>
										<title>1960 - 1962 Corvette: Chevrolet Central Office Letter: Aluminum Radiator Factory Replacement Policy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-chevrolet-central-office-letter-aluminum-radiator-factory-replacement-policy-762.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-radiator-replacement-242.html</guid>
										<title>1963 - 1967 Corvette: Technical Article: Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-radiator-replacement-242.html</link>
