<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-hood-latch-striker-bolt-649.html</guid>
										<title>1992 Corvette: Service Bulletin: Hood Latch Striker Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-hood-latch-striker-bolt-649.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</guid>
										<title>1990 Corvette: Service Bulletin: Competition Yellow Paint Comments About Color Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-convertible-mounting-bracket-rattle-at-rear-of-hardtop-656.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Convertible: Mounting Bracket Rattle at Rear of Hardtop</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-convertible-mounting-bracket-rattle-at-rear-of-hardtop-656.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Starter Inoperative/Clicks/No Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Revised Code 42 Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</link>
