<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</guid>
										<title>1990 Corvette: Service Bulletin: Inflatable Restraint Indicator Lamp Stays On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</guid>
										<title>1992 - 1993 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</guid>
										<title>1984 - 1996 Corvette:  Wiring and Circuit Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
