<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</guid>
										<title>1963 - 1967 Corvette:  Chevrolet Service News:  Two-Unit Voltage Regulator Diagnosis and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  RPO K-66 Wiring Diagram for Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-wiring-diagrams-for-breakerless-ignition-systems-903.html</guid>
										<title>1966 Corvette:  Service News:  Wiring Diagrams for Breakerless Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-wiring-diagrams-for-breakerless-ignition-systems-903.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-transistorized-voltage-regulator-failures-1219.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Transistorized Voltage Regulator Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-transistorized-voltage-regulator-failures-1219.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Distributor Breaker Point Burning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</guid>
										<title>1966 Corvette:  Service News: Corvette Radio Speaker - Replace</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</guid>
										<title>1965 - 1966 Corvette:  Service Bulletin:  Temperature Gauge Reading Too High</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</guid>
										<title>1963 Corvette:  Delco Service Bulletins:  Delco Radio Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</link>
