<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-lifting-the-corvette-zr1-107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink Article: Oil Reservoir Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-service-guide-unique-characteristics-dealer-service-information-for-2009-chevrolet-corvette-zr1-155.html</guid>
										<title>2009 Corvette ZR1: Service Guide, Unique Characteristics, Dealer Service Information for 2009 Chevrolet Corvette ZR1</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-service-guide-unique-characteristics-dealer-service-information-for-2009-chevrolet-corvette-zr1-155.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</guid>
										<title>2009 Corvette ZR1: Campaign Recall:  Clutch Spring Fracture-Replace Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</guid>
										<title>2009 Corvette ZR1:  Front Fascia Valence Panel Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</guid>
										<title>2009 Corvette Z06 and ZR1: GM TechLink Article: Oil System Changes - LS7 and LS9</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvettes-all-models-grand-sport-stripe-kit-part-numbers-1184.html</guid>
										<title>2005 - 2013 Corvettes - All Models:  Grand Sport Stripe Kit Part Numbers</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-installing-zr1-body-kit-108.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Installing ZR1 Body Kit</title>
