<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-chevrolet-product-engineering-technical-information-increased-capacity-fuel-pump-1068.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-corvette-fuel-injection-modifications-735.html</guid>
										<title>1963 Corvette: Zone Letter: Corvette Fuel Injection Modifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-corvette-fuel-injection-modifications-735.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</guid>
										<title>1965 Corvette:  Engineering Service Letter:  Engine Bucking and Faltering</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Oil Level Gauges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</link>
