<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</guid>
										<title>2015 - 2018 Corvette Z06: Special Coverage Adjustment - N202302720 On Track Performance Engine Overheating</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-stingray-and-z06-gm-techlink-v8-engine-surge-sensation-during-highway-driving-1419.html</guid>
										<title>2014 - 2016 Corvette Stingray and Z06: GM TechLink: V8 Engine Surge Sensation during Highway Driving</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-stingray-and-z06-gm-techlink-v8-engine-surge-sensation-during-highway-driving-1419.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin: #PIP5179D: Extended Crank Cold With DI (Direct Injected) Engines - (Mar 27, 2018)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Engine Repair with Crankshaft Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</guid>
										<title>2017 Corvette Z06: GM TechLink: Supercharger Idler Pulley Sounds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Coolant Entering Engine Cylinders</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</link>
