<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-low-tire-pressure-warning-system-sensor-part-numbers-494.html</guid>
										<title>1989 - 1996 Corvette: Low Tire Pressure Warning System Sensor Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-low-tire-pressure-warning-system-sensor-part-numbers-494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1968-corvette-chevrolet-engineering-service-letter-corvette-auto-jack-low-height-restriction-34.html</guid>
										<title>1953 - 1968 Corvette: Chevrolet Engineering Service Letter: Corvette Auto Jack Low-Height Restriction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1968-corvette-chevrolet-engineering-service-letter-corvette-auto-jack-low-height-restriction-34.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-uneven-wear-outer-ribs-on-corvette-tires-40.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Uneven Wear-Outer Ribs on Corvette Tires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-uneven-wear-outer-ribs-on-corvette-tires-40.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Cast Aluminum Wheel Porosity Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</guid>
										<title>1988 Corvette:  Product Safety Campaign:  Product Safety Campaign No. 88C09 - Possible Missing Wheel Weld</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-coated-wheel-weights-for-aluminum-wheels-497.html</guid>
										<title>1985 - 1991 Corvette: Service Bulletin: Coated Wheel Weights For Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-coated-wheel-weights-for-aluminum-wheels-497.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-ltpws-parts-numbers-and-sensor-color-codes-revised-1105.html</guid>
										<title>1991 Corvette:  Service Bulletin:  LTPWS Parts Numbers and Sensor Color Codes Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-ltpws-parts-numbers-and-sensor-color-codes-revised-1105.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Tires Slipping on Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</link>
