<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-lifting-the-corvette-zr1-107.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Lifting the Corvette ZR1</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-lifting-the-corvette-zr1-107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</guid>
										<title>2006 Corvette Z06: Dry Sump Oiling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-brake-burnish-procedure-129.html</guid>
										<title>2009 - 2013 Corvette ZR1:  GM TechLink: Brake Burnish Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-brake-burnish-procedure-129.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</guid>
										<title>2009 Corvette ZR1:  Front Fascia Valence Panel Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</guid>
										<title>2009 Corvette ZR1: Campaign Recall:  Clutch Spring Fracture-Replace Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</guid>
										<title>2007 Corvette Z06: Dealer Bulletin: Addition Of Optional Z06 Chrome Wheel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: 2005-2006 Chevrolet Corvette Including Z06 Repair Procedure for Painted Roofs that may separate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-installing-zr1-body-kit-108.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Installing ZR1 Body Kit</title>
