<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Oil Level Gauges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</guid>
										<title>1966 Corvette: Engineering Service Letter: Overheating at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-advance-information-engine-crankcase-backfire-1253.html</guid>
										<title>1963 Corvette:  Chevrolet Advance Information:  Engine Crankcase Backfire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-advance-information-engine-crankcase-backfire-1253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Increased Capacity Fuel Pump</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Top Radiator Inlet Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</guid>
										<title>1963 Corvette: Service News: Radiator Service Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</link>
