<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-steering-shaft-lower-bearing-spacer-1058.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: In-Vehicle Corvette Steering Gear Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</guid>
										<title>1963 - 1967 Corvette: Engineering Service Letter:  Steering Effort on Booster Type Power Steering Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</guid>
										<title>1964 Corvette: Service News: Steering Ratios</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</guid>
										<title>1963 - 1964 Corvette: Lubrication Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</guid>
										<title>1963 - 1971 Corvette: Service News: Lubrication of Rear Wheel Inner Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</guid>
										<title>1963 Corvette: Service News: Hydraulic Steering Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-steering-dampener-control-744.html</guid>
										<title>1963 Corvette: Chevrolet Inter-Organization Letter: Steering Dampener Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-steering-dampener-control-744.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Revised 1963 Corvette Rear Wheel Spindle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</link>
