<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-powerglide-production-variations-1056.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</guid>
										<title>1953 Corvette: Service Bulletin: New Spoke Flywheel and Converter Attachment to Flywheel - Late Powerglide Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</guid>
										<title>1953 - 1954 Corvette:  Service News:  Powerglide Clutch Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Upshift at Part Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</guid>
										<title>1956 - 1957 Corvette:  Service News:  Corvette Transmission Mount</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Excessive Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</guid>
										<title>1955 Corvette: Service Bulletin: Foreign Material in Clutch Housings, Secondary Road Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</guid>
										<title>1955 Corvette: Service Bulletin: Rear Engine Mountings 1955 Passenger 6 &amp; 8 Cylinder With Powerglide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
