										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rocker-arm-cover-gaskets-185.html</guid>
										<title>1985 Corvette: Service Bulletin: Rocker Arm Cover Gaskets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rocker-arm-cover-gaskets-185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</guid>
										<title>1994 - 1996 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: Tail Pipe Smoke on Startup</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Rebuilding the LT1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-lt1-reverse-flow-cooling-system-526.html</guid>
										<title>1992 - 1996 Corvette: Technical Article:  LT1 Reverse Flow Cooling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-lt1-reverse-flow-cooling-system-526.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Radio Condition Remove/Replace Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</guid>
										<title>2000 Corvette: Service Bulletin: Tech - Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</link>
