										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Reduced Engine Power Message Along With Partic. Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</guid>
										<title>2004 Corvette:  Campaign Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-premature-wear-of-leather-material-on-bucket-seatback-bolster-384.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Premature Wear of Leather Material on Bucket Seatback Bolster</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-premature-wear-of-leather-material-on-bucket-seatback-bolster-384.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Fuel Tank System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Corvette Engine Low Coolant MIL</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</guid>
										<title>1997 - 1999: Service Bulletin: Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-check-gauges-light-battery-voltage-low-accessory-drive-belt-slipping-or-missing-install-crankshaft-balancer-and-washer-from-wpc-331.html</guid>
										<title>2005 Corvette: Service Bulletin: Check Gauges Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Crankshaft Balancer and Washer from WPC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-check-gauges-light-battery-voltage-low-accessory-drive-belt-slipping-or-missing-install-crankshaft-balancer-and-washer-from-wpc-331.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
