<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Ignition Timing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</guid>
										<title>1960 Corvette:  Service Update:  Tachometer Erratic Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Generator Belt Misalignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-radio-interference-900.html</guid>
										<title>1959 Corvette:  Service News:  Radio Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-radio-interference-900.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-news-setting-v-8-timing-at-1-000-engine-rpm-discontinued-1210.html</guid>
										<title>1955 - 1957 Corvette: Service News:  Setting V-8 Timing at 1,000 Engine RPM Discontinued</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-news-setting-v-8-timing-at-1-000-engine-rpm-discontinued-1210.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Temperature Gauge Erratic During Normalizing Period</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</guid>
										<title>1955 - 1957 Corvette: Service Bulletin: V-8 Distributor Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</guid>
										<title>1955 Corvette:  Zone Letter:  Directional Signal Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-news-fuel-gauge-diagnosis-1050.html</guid>
										<title>1971 Corvette: Service News:  Fuel Gauge Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-news-fuel-gauge-diagnosis-1050.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
