<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</guid>
										<title>1957 Corvette:  Inter-Organization Letters:  Fuel Injection Issues</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Hydraulic Valve Lifter Adjustments</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-holley-carburetors-primary-fuel-inlet-float-needle-sticking-closed-1204.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Holley Carburetors - Primary Fuel Inlet Float Needle Sticking Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-holley-carburetors-primary-fuel-inlet-float-needle-sticking-closed-1204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</guid>
										<title>1965 - 1967 Corvette:  Tonawanda Engine Service Notes:  Valve Springs, Rocker Arms, Camshafts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</guid>
										<title>1957 Corvette: Service News: Fuel Injection Pump Drive Shaft Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
