<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-inadequate-cooling-1025.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</guid>
										<title>1969 Corvette:  Service News:  Delcotron Battery Terminal Contacting Rocker Cover</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<title>1970 Corvette:  Service News:  1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Upper Radiator Hose Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</guid>
										<title>1968 Corvette:  Service News:  Tune-up Specification Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</link>
