<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Top Radiator Inlet Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</guid>
										<title>1966 Corvette: Engineering Service Letter: Overheating at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</guid>
										<title>1964 Corvette: Service News: Servicing 1964 Corvette Fuel Injection Units</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</guid>
										<title>1967 - 1968 Corvette:  Engineering Service Note:  Idle Cooling and Dieseling on Corvette with 427 CU IN Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-propeller-shaft-balancing-746.html</guid>
										<title>1963 Corvette: Chevrolet Inter-Organization Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-propeller-shaft-balancing-746.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
