<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</guid>
										<title>1976 Corvette:  Parts Chart:  Delco Quadrajet Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</guid>
										<title>1974 Corvette: Service Bulletin: Soft Push Rod Guides</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Incorrect Camshafts in Production at Flint Engine Plant</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cold Start Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</guid>
										<title>1968 Corvette:  Service News:  Tune-up Specification Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</guid>
										<title>1981 Corvette: Service Bulletin: Poor Engine Performance, Catalytic Converter Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
